February 16, 2026, 03:33:01 am
are tables interchangeable?
Started by christwo, June 19, 2011, 08:23:15 am
christwo
if i were too buy a different make machine, would the table that i have for my juki ddl 555 house a different model or make?
I'm nit familar with your model but mu singer 11w155 Nd juki Lu 153 use the same table
I'll bet Greg will
step up and know.
Jim101
Without looking at the set-up on your table the answer I have would be a definite maybe.
You would likely need to adjust the belt tension for a different machine, (not too difficult) and the knee lift apparatus that you have now may not line up quite right with another machine, (a little more difficult to arrange).
There are a few machines, the Pfaff 1245 being one of them, that have a dedicated rear attachment to the table but most have the hinge dogs that insert into the bed on the rear of the machine and are largely interchangeable.
What type of machine are you looking at for a replacement?
Jim
What speed motor is on the DDL-555?
If it's a 3450 rpm, you would want to switch to a 1725 rpm
Everything else should match up. Maybe a different belt.
christwo
i would like to just go to a walking foot model, if a juki an lu or a dnu.. but hopes are not set on a juki, whatever i can get reasonably really. thats why i want to know, because if i get a singer or a consew for instance i need to know if i need to get a new table as well or if i can jsut get a head
Speaking of tables, I need to get down there and get that one from you Mike. We are planning on coming your way in July sometime.
Sorry rich I don't have the table anylonger.  I needed the garage space
Quote from: sofadoc on June 19, 2011, 10:38:22 am
3450 is too fast for a walking foot, and, the 1,000,000 question...what machine are you going to try to drop into this table top cutout?  BTW...the knee lifter and drip pan would have to be replaced, too.
christwo
i have a rex 512dv modle motor right now, and it has a 110/230 switch on it which switches the rpm as well.. on 110 it runs at 1750 and on 230 it runs at 3450.. i guess what i want to know then are what walking foot machines could i drop into that table.. because that would direct my choices
Quote from: christwo on June 20, 2011, 08:49:29 am
Honestly, dozens, of brands, makes and models.  DDL-555 uses a very populuar cutout.
