February 06, 2026, 12:25:58 pm
Which hand stapler ,plier type do you use?
Started by forsailbyowner, April 08, 2011, 06:04:53 am
forsailbyowner
Doing a 60 guage strataglass job and having more staples bend than penetrating. What model/make stapler do you use? Looking at Bostitch STCR2619. Wondering if something like the B8HDP Heavy-Duty Plier Stapler would have too thick a wire and would leave noticeable puncture marks. TIA
I don't stae mine I just cut the spass t the size need and add facing if needs I'll remove the strat like at the bottom where I'll need to install lift the dots or commonsence
This is similar to the one I use but it is chrome and a different brand.
I think I bought mine off Amazon for a whole lot less money. It works great and the holes are not to big.
http://cgi.ebay.com/Industrial-Hand-Stapler-/190487165238?pt=LH_DefaultDomain_0&hash=item2c59eb7936
What are you stapling and why? windows? Hmmmm. 60ga. Hope you have a servo motor cus you're gonna need to sew that real slow too. I have the bostich. Works great on vinyl and sunbrella , never used on clear vinyl though.
forsailbyowner
Im using tape but the tape only holds the sunbrella marginally, im putting an occasional staple in it to avoid the movement of the facing. Its aggravating when lining up both sides to find the bottom piece had moved while sewing and the stitches miss the fabric,
hdflame
Bobby
www.sunstopper.biz
Several Old Singers
Elna SU
Older Union Special
Quote from: scarab29 on April 09, 2011, 05:09:19 pm
60 sews just  fine with my clutch motor no different then 40 imo sewing
