February 02, 2026, 05:58:29 am
Highlead bobbin questions
Started by edp, February 19, 2011, 11:37:53 pm
Quote from: hdflame on February 21, 2011, 06:44:15 am
Quote from: hdflame on February 21, 2011, 05:40:53 am
Quote from: edp on February 20, 2011, 11:27:14 pm
Gregg @ Keystone -  since I see you're a Highlead dealer maybe you can recommend a particular pulley size for the motor (smaller) as I want to slow the machine down for better control. I'm getting the hang of this thing but slower would definitely be better. Its got the clutch motor setup, got any ideas?
Thanks ,Evan
The best thing I could recommend would be to spend $155 bucks (or there abouts) and buy the servo motor from Gregg.  All problems solved, total control, quiet operation, only use power while it's sewing.
Just my 2 cents, but I bet others would say the same.  Once you've tried a servo, you'll wonder why you ever tried to struggle to control that clutch motor.
"Pulley 613, 2" OD, $6.50 in stock."
.......or spend $6.50 and try the pulley. :D
The Servo motor is a better option, you are correct sir!
