February 09, 2026, 05:25:39 pm
Boat Cushions
Started by Allan, December 16, 2010, 01:55:08 am
Allan
Not being a cushion person I have a question
I am building a couple of cushions for the flybridge of my boat and they will be out in the weather all the time however under the bimini.
I am covering them in Sunbrella canvas
The foam is high density foam that will allow the water to flow straight through
Question
If I cover the whole cushion in Sunbrella will that retain water?? or
Should I put Textaline on the bottom of the cushion to allow drainage and ventilation??
Allan
I put Textilene on mine Allan. I believe it will help drainage ads well as allow the cushion to breathe.
But then I am not a cushion guy either. But that textilene sure gave me a warm and fuzzy and I have so many scraps around I thought I would use it. :)
TimsTrim
Alan, if you can do without reversible cushions, I'd highly recommend a bottom that lets moisture out. Sunbrella is water resistant but not water proof. If water stands on it it will go thru eventually, and then you want to make sure the water can get out.
Like the others say - use mesh.  Even with vinyl covers which IS waterproof, the foam will find a way to get wet.
If t was me I'd use mesh on he bottom.
I've done total cushion with mesh and dryfast. / ez dry foam  open cell.
Allan
Thanks all
Just confirmed what I thought
Allan
