February 02, 2026, 09:17:01 am
206RB5 taking chunks
Started by nyuphol, October 30, 2010, 12:40:53 am
nyuphol
how do I get my consew 206RB5 stock foot from taking a chunk out
of the vinyl when im going to top stitch and going over a double folded seam
and the machine jumps when its really not to much of a bump....
Any input would be great help
SHHR
Is the foot smooth or serrated on the bottom? When I bought my machine it was serrated and it would chew up some top stitching, but not all. I changed it out for a smooth bottom one and it works great now. As for jumping, are you talking about when sewing across another seam or a spot with multiple layers? Mine again will jump and I even broke two needles on a pool cover repair this week sewing through 3 layers of vinyl and three layers of poly webbing. I just had to stop and hand wheel the machine through and it worked fine.
Hope this helps,
Kyle
Have you considered the presser foot pressure setting? on my singer 111w155 it's a thumbscrew on top of the machine. I was having similar problems with my machine (after moving across the country) when i realized the movers had screwed that all the way in! Backed it off a few turns and now it works fine.
fingers
 My Pfaff will tear the vinyl on welt as I go around sharp corners. Not your machine I know but in this case simply lifting the foot via my knee relieves the pressure and solves the problem.
Jojo seems to have a good starting place with foot pressure and Kyle with wheeling by hand for a few stitches.
Factory standard foot is smooth with slot in front of inside foot.  As for jumping....not sure what you mean.
November 01, 2010, 08:45:38 am #5 Last Edit: November 01, 2010, 04:42:10 pm by scarab29
gotta be the foot. I get that with one of my welting feet sets. Recently bought a new set from Greg (above post ) and it is shaped a bit different on the back of the big foot where the material was bunching up , no more , problem solved.
I just looked at the keysew site and remembered I bought the welt set with the back cut out. Thets what made the difference and kept the material from bunching up when you go over intersecting seams and thick layers. Other than this I prefer the origional foot set.
