February 02, 2026, 12:42:25 am
Unsewing (ripping) a double fell seam (French Seam)
Started by baileyuph, October 16, 2010, 05:52:18 am
On occasion it is desireable to separate such seam, particularly in auto original seat repairs.  It actually involves ripping three seams and does take time which is the thrust of post.
Anyone found a neat way to separate these described seams?  I use blades and seam rippers in an inefficient manner, time is money.  Any ideas or good experience to share with this?
SHHR
The only way I know Is plenty of time, a sharp razor blade, and a great understanding of four letter words!!
Kyle
BCKC
Hi ya Doyle,
You know......if your talking leather easy fix for older seats.....lay your razor flat as you can get it on the table and with a even stroke down the top fell seam you slice like  a hot knife through butter.
Then through your center main seam and there you have it. I then will cut off the first center seam leather and use fell seam for new center seam and i get to sew a whole new fell seam!
Most older leather seats because it streches with time can take the adjustment with nobody the wiser. Good clean look. Fabric bites a big one no matter how you do it :D Vinyl is well...like leather in about the same way but you better be dang good at slicing and dicing the stuff....hehe
Good luck and let me know if there is something better!!! Im always looking for the newest and easiest way with great quality to boot!
Karen
Um...I just reread this post and I can hardly make no nothin out of it...lol....hope it helps...
Always keep your words soft and sweet, just in case you have to eat them........http://www.candcupholsterydesigns.com
Karen I read you loud and clear:  You made three clear points.
   1.  Keep a sharp razon at a low angle
   2.  Where there is enough tail, just cut off some and move the seam over a bit, avoids the futility of hitting the holes when seaming back together.
    3.  Then, there is the Karen factor.   ;)
LOL,
Regarding this subject, you will never see a grown guy get so happy when encountering a chain fell seam, just pull and go.  ;D
Thanks all,
Just a reminder of the obvious, the sharper the blade the better you can feel whether you're cutting thread or about to have a problem.
stitcher_guy
I do it every day, and the easiest way I've found is a NEW seam ripper. It has to have the little red ball on the short side. If it does, I have great luck sliding down under the selvage, slicing out that seam, and then just yanking it apart. But, heaven help the trimmer who uses one without the little ball (they fall off quick).
Otherwise, I use a bit of brute strength for double fells and frensh. I do a normal rip up about an inch or two. Then I position the main panel over the edge of my cutting table and lean up against it. Grab the attached panel and pull it out. Just that tugging will open up 4 or 5 lines of seam. If I'm feeling lucky, I'll tap with a razor blade and slice right through. Otherwise, I'll use my seam ripper.
