February 09, 2026, 09:44:22 am
ottoman
Started by n01945, October 04, 2010, 05:46:11 am
n01945
Hi - I'm working on a long ottoman w/ a striped fabric. The width of the fabric is  1" short on each side from where the original boxing/welt was stapled. Would you add 1" to the boxing height, or would you add additional fabric on each side. This would make a seam though so I'm not sure which way to go since I'm soooo close.  I've pulled it so tight to the original welt line, the tacks kept popping out! Good thing I was wearing my glasses - yikes!
Any thoughts?
Nora
Now I don't do furniture, but in the past when I've made horrible mistakes in boat covers or whatever, I try to modify by adding a "design element".  Feature it!  I'd probably add a strip to the boxing in a complementary or contrasting solid color.  I assume your stripes in the boxing are vertical?  You could add a "frame" to the top plate, making it bigger, but would the edges line up the right places on the edge of the cushion?
ThrowMeAPillow
I can't imagine doing anything except seaming the top to make it the proper width.  pulling and stretching is a bad idea.  If I understand you properly, adding to the boxing would bring the welt up to the top to make up for the top being too short to make it... not a good idea.
Do the stripes run the length of the ottoman, or the width? If the stripes run the width, and I understand correctly that the width of the fabric is not wide enough, then if you add fabric to the width, you will need to match the stripes when you sew on extra fabric.
If you add an inch to the boxing height, is there wood underneath at that place to staple into?
Another idea, (pictures would be helpful to know if this is a good idea or not), is: if there is wood at the 1" higher place, staple the top fabric at this point, along with the corner pleats. Staple single welt cord all around at this point also, then staple the boxing fabric upside down on the welt cord, add chip strip to keep the welt cord nice and straight, add a little batting, then pull the boxing down and staple under the ottoman. Add welt cord around the base of the ottoman and you will have the boxing outlined, top and bottom, with welt cord. This can be a great look, depending on the ottoman and the fabric and where it is going to be used, etc.
Good luck,
Gene
PS: When you have the top fabric on the ottoman, slide your hand across the fabric and down the side, this is as tight as you want the fabric.
I would take some remnants & see how it seams. Usually putting your seam in the centre of the lighter colour gives your best result. Obviously cut one piece 1/2" right of centre ,one 1/2"left of centre and use 1/2" allowance. Once sewn spray glue the salvage and the material on both sides and fold back like a french seam (or a luggage seam if you're a shoemaker) , then "roll" it with a wallpaper roller or the business end of a hammer like you're ironing it. Unless it's tissue paper thin the seam will go "bye bye". I just did the inside back of a tub chair for a motor home out of 5 pieces of the old plaidfabric (They didn't want to redo the three of them to match the new couch) . My boss has over 30 years experience and could not find the seams once I "quilted" it up.
