February 09, 2026, 04:07:35 am
stitch length changes
Started by jeepdoc, August 17, 2010, 08:36:35 pm
jeepdoc
I have a singer 111w153 machine If i sew 2 layers stitch length at spec if I use my welt foot while sewing welt noticed  length is cut in half----normal? I tried messing with upper foot pressure nothing made it better or worse. If i try top stitching through 3 layers of vinyl lenght falls short of what it should be any ideas?
Perhaps your machine's feed dogs are too low.  Sometimes they loosen with time and all you have to do is tighten the screws that hold them in place.
jeepdoc
thanks bobbin ive been messing with it I did adjust the feed dogs and also found that the presser foot height adjustment slipped some seems better now
Quotewelt noticed  length is cut in half----normal?
I had similar experience and it too turned out to be walking foot adjustment.
It turned out to be a good learning experience, now I can do the adjustment.  Checking the feed dog height would be part of the adjustment also.
jeepdoc
Yeah never thought about checking the feed dog screws they were so loose suprised it didnt fall apart
