February 01, 2026, 05:45:29 am
Enclosure Top Pocket
Started by regalman190, June 30, 2010, 10:15:16 am
Problem with an enclosure top I installed yesterday. Patterned the way I always do, tensioning the frame, marked seam lines, etc. Made the top and installed.
The front bow pockets were my problem. The pockets fit tight at the sides, but the pocket was loose at the middle.  >:( The frame seemed fine, not bent and in the same position as when I patterned.
Had to do some readjusting of the frame, but I cannot figure out what may have gone wrong.
Is it possible that the frame could have been over tensioned?
Any thoughts?
Joe
I get this sometimes as well, usually with the wider frames 2.5 / 3m plus.
I get the feeling that it's just the expanse & the pole is bowing inwards a tad. Like it needs a centre strut.  Or a centre pull out strap ?
If it's on a yacht, sometimes the owners have been forcing it down to pass under the boom, not bothering to lift the boom with the topping lift.  Hence putting a nice wobbly bend into the leading pole.  >:(
R.A.F. CaNvAs
Quote from: Grebo on July 01, 2010, 06:21:04 am
si exactamente jefe, un mas fasil reparation hacer poco mas curva en el tubo.
July 01, 2010, 01:15:16 pm #3 Last Edit: July 01, 2010, 01:21:26 pm by fragged8
translation pls Grebo  :-)
something like if all else fails fix the curve in the tube ??
or poco mas curva,
little more curve in the tube ?
Quote from: fragged8 on July 01, 2010, 01:15:16 pm
or poco mas curva,
Yes, more or less  ;D.   I never said I was Spanish  ???  :-*
my spanish is about good enough to get fed and watered  :-)
Quote from: fragged8 on July 02, 2010, 10:52:15 am
Dos cervezas muy frio! por favor...
Pikachu
"si exactamente jefe, un mas fasil reparation hacer poco mas curva en el tubo."  =  Yes, exactly, boss. The easiest fix is to put a little more bend in the tube.
Quote from: JuneC on July 02, 2010, 06:40:50 pm
And what more does one need ?
;D
always makes my eyes water  :o
too much tube bending can't be good for you   :P
R.A.F. CaNvAs
I like a tight one myself,
But you guys might enjoy it floppy and wrinkly here and there  !
July 05, 2010, 03:54:49 pm #11 Last Edit: July 05, 2010, 03:57:08 pm by fragged8
hiya
nice work amigo, i only hope the one i'm doing this week looks
as er.. stiff ...
where the bow exits the long pockets you have it nice and close
to the bow, do you have a trick for that ? because most i've seen
have slack there .
rich
R.A.F. CaNvAs
Sorry no trix,
Just a few illusions a spot of conjuring and some juggling of  time and finances  thrown in there and asif by magic it appears on the boat !
Must be slowing down in my old age this one took  11 hours from pattern to fit,
There was a  howling zephyr  that was blowing across the marina while patterning.
But that's no excuse eh?
Really ..... It's only girls work eh, Playing with fabrics and sewing machines ! ; ::)
Hasta luego, Cabeza hueca
I'm an equal opportunities boattopper. I like 'um floppy and wrinkly, tight and wrinkly, floppy and wet, ect.
I tell people their tarps are figments of my imagination. At least I can see wrinkles in this one. I guess you should've spent 12 hours, eh? Or found working girls maybe?  ^_^
looks aweet Raf BUT AS RICH SAID IT LOOKS LIKE THE LONG POCKET ARE FULL LENGHT AS THE TOP no room for a window. i normally stop my pockets back 2" for room for a zipper and window with room for a flap. but it looks ike no windows are wanter on yours. anyway top notch work for sure. :D
my son also said sewing is wemons work and wanted no part of it.one day when i took him to bike week at laconis New Hampshire. like Sturgis and he saw a burly old bearded leather clad biker sittign at a sewing machine sewing patches and do alterations to leather chaps I told my boy to go tell that to this guy  ;D
