June 14, 2026, 01:05:12 pm
Replacing part of an enclosure
Started by timtheboatguy, June 13, 2010, 08:04:19 pm
timtheboatguy
I have a customer that wants me to replace about half of his eisenglass. How can I do this and get the zippers to match up? Should I also replace the zipper half in the window pieces that I am not replacing? I am also concerned about getting the new pieces to fit good without wrikels etc. so what is the best way to pattern the replacement windows?
Please excuse my extreme lack of intelligence ???
Tim
http://www.timtheboatguy.com
Douglas MacArthur
hiya
normally you don't replace the fabric part, what you do is sew the new window over the top of the old one
In other words leave the old one in place and sew the new one right on top using the same
stitch lines.
when stitched in you then carefully cut away the old window from the outside and
as close to the stitching as you can.
If the panel window is broken already the panel can change shape and not fit when
you fit it back on the boat so take some duct tape with you and firmly tape up any holes
while the panel is fitted on the boat to maintain the panel shape.
If the window is mostly vinyl, and depending on how bad the window is, I'll just use the old as the template and match the zipper placement. You could also stay stitch a zipper on to pattern material, zip it to the top and mark your pattern accordingly (side zips, etc.). If it's mostly fabric, then I'll do as Rich stated....just replace the vinyl.
timtheboatguy
Douglas MacArthur
Id do like they bolth said but If I was going to pattern a new panel on the boat what I doo is I zip the new zipper onto the existing zipper o n the boats top and adjacent windows then I take my patternign plastic and clap in to the zippers and the snap it to the snaps on the boat with a binding tape with snaps in it snapping right over the plastic. then mark all seams zipper locations stats and stops ect and your go to go.
