February 02, 2026, 03:44:42 am
53 Ford Windlace - 2dr post sedan
Started by baileyuph, May 26, 2010, 05:47:08 am
Anyone who has got into the job of windlace for the 53 (specifically 2 dr post) will know what the small piece of rubber sewn into the edge of the windlace looks like; I could use that or a close simulation.
I have a piece of the original rubber, shaped like an "L", 1/8th inch thick and the legs (of the "L") are  1/4 inch and 3/8ths inch respectively.  The longer side is sewn into the edge of the windlace.
The rubber is not real soft but enough for a needle to go through it.
I googled for vintage ford interior supplies, but was surprised how little I found.  Is there a forum or a link that would have resolved this to your knowledge.  The interest in this year must be small.
Thanks for any information.
SHHR
Go online and check, Mac's, Dennis Carpenter, or Earlyford.com. They all are excelent at ford reproduction  parts. You may also check out Kanter Auto Products, or Restoration Specialties. They carry lots of rarer items.
Kyle
M-E Fabrics
Doyle.
Try Metro Moulded Rubber.
http://www.metrommp.com/
They make ALOT of repro weather stripping and extruded rubber for antique autos.
We use a similar L extrusion to what you discribe for roll-up window wiper-seals. It's Metro's #LP107. You may have to trim back one leg of the "L".
Also Karr Rubber in Calif. makes just about all the extruded rubber that the other restoration parts supply guys sell.  They have a number of L shaped extrusions, but they don't list sizes in their catolog, just drawings printed close to actual size. You'll have to call and ask John to look, or ask him to send you a catolog and compare!  ;D
Karr Rubber MFG. 800-955-5277.
Good luck,
Paul.
First thanks to the responses to this question, your research and time given to responding is noteworthy.  Big Thanks!
Paul, I did take your idea and it will likely get me out of the woods, so to speak.  I am sewing  a stiff plastic bead to the windlace to for the "L" form, it looks like it will work.
There are times we have to think outside the box, for sure.  Walmart doesn't cover all requirements. ;)
