February 03, 2026, 11:31:59 am
Narrow crown stapler
Started by gene, June 12, 2018, 05:31:16 pm
When you use a narrow crown staple to secure the corners of double welt cord, do you use the 18 gage narrow crown staple that Harbor Freight guns use?
https://www.harborfreight.com/18-gauge-2-in-1-air-nailerstapler-63156.html
Or do you use a narrow crown stapler that has staples as thin as the Series 7 staples?
Gene, I bought the harbor freight gun. The staples are to thick to be useful on DW. I finally found a gun from Senco that shoots the thinner staples. It makes a bit difference. But they still make the stapled area noticeable. There is no way around it. But the HF stapes are just too fat.
https://www.amazon.com/gp/product/B00BPBCTDY/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I use the narrow crown and series 7 staples. The HF tool is not good for double welt.
But, for corners, glue.
Thank you for the info. My memory is good enough to remember that this was talked about before on this forum, but my memory is not good enough to remember what was said.
On some ornate wood carved or antique furniture there are sometimes acute angles that the double welt cord needs to fit into. I always find a gimp tack or the narrow staple. I usually tap in a brad nail with a head on it which is a real pain to do. My fingers are not so nimble any more.
I sometimes use a brad nail gun to anchor corners on DW.
I used to have a "gimp gun", which was a 1/4" crown 20 gauge stapler. When it crapped out, I never tried to replace it.
I have a duo fast 3/16th crown 23 gauge stapler.  You can bury a staple without seeing it but the hard part is not making a dent.
I guess if I was working on something that needed to be perfect - no dent but required holding power I'd consider putting a stitch with a curved needle -
I bought a pack of gimp nails to copy the way gimp was attached in the last century for a chair I did last year.  . That was nice and easy - no glue - the nails are meant to show -
