February 02, 2026, 07:29:09 am
Banquette cushions
Started by cleanqueen, February 09, 2017, 05:32:11 pm
cleanqueen
I finished a cushion with 3 inch foam and 5/32 welt cord.  I don't know if the cushion cover is too small because the welt cord does want to lay on the edge.  I wrapped the cushion with batting with spray adhesive.  Any tips or suggestions?
I generally cut my top and bottom plates the same size as my foam---1 " bigger than finished dimensions. I then cut my border 3 1/2". This places the welt just below the crest created by the batting so you don't feel it when you are sitting. If you want a real square/boxy looking cushion you would have to cut your border 4" and make your panels smaller to put some tension on the foam.
