February 10, 2026, 06:22:12 pm
Favorite tools?
Started by byhammerandhand, March 27, 2015, 08:31:25 am
Time to (re-)run a poll on what is your favorite tool(s).
This is one of my most-used tools doing repairs.   The handy kit contains metric and SAE sockets, SAE hex (Allen) wrenches (I added a set of metric), Torx, Phillips, slotted, and Robertson screw drivers.   Takes standard 1/4" drive so any third party drivers easily added.  Lots of torque for tight connectors.   Fast insertion and removal (especially with Allen head connectors).  Great for fitting in tight spaces where you'd otherwise need a stubby screwdriver (that are sometimes even too long).   Great for arthritic hands.
A deal for $17 at Amazon.
http://www.amazon.com/GearWrench-85035-35-MicroDriver-Set/dp/B0062FSAVI/ref=sr_1_sc_1?ie=UTF8&qid=1427470176&sr=8-1-spell&keywords=35+pc+mcrodriver
March 27, 2015, 09:42:43 am #1 Last Edit: March 28, 2015, 08:11:00 am by sofadoc
This is my favorite. I actually have 3 of them. They're really cheap at places like Harbor Freight and Northern. I keep a set of adapters with all different bits handy to snap on when I need them.
I can disassemble a La-Z-Boy in under 4 minutes. I love being able to go from forward to reverse with the flick of my thumb.
Hand Tools -  it's  clamps - one of my favorite tasks is figuring out how to clamp odd shaped pieces together
Portable Power Tools - 7-1/4 circular saw - DeWalt
Stationery power - 14 inch Rockwell band saw from 1958 - weight 400 lbs. all cast
Here are some things that I do for odd shapes:
1. I bought some web ratcheting tie downs.  4 for about $20.   Took off the short end by removing a bolt.  Re-sewed the long end back on and now I have a 15' web clamp with ratcheting cinch and 2" wide web.
2. Got a bicycle innertube and cut into a long strip.  Wrap around your odd shape and keep pulling tight as you add additional wraps.
3. Packing tape.  Stretch over the joint and fasten down
4. Made some cauls of scrap plywood about 3" and 8" long.   Put a 45 degree block on one end and a square block on the other.   Clamp one down on each of the two parts and then run a clamp between the end pieces.
Quote from: SteveA on March 27, 2015, 10:50:24 am
Yes clamps and clamping jigs - I'm all in.  Another easy technique is I use a pin nailer - glue and pin the pieces together and you'll never see the pin hole.  When the glue dries - there's your strength
Quotenow I have a 15' web clamp with ratcheting cinch and 2" wide web.
With 2" you probably would have to resew like that. I just use one of 1" straps by hooking the two hooks together or hooking the long end onto the ratchet. That way I still have them to tie a load down on the truck.
Yes, I started off just hooking the two metal ends together, but worried that it might damage the wood one day.   I left the hook on the long end of the web, so I can with a wrench or two, reverse the configuration and use as a tie-down again.
Quote from: Darren Henry on March 28, 2015, 07:24:49 am
I have a hammer sort of like this one.
I seem to use it on every project that comes up. The guy down the sidewalk from my shop put a new hickory handle on it a few years ago.
http://www.harborfreight.com/4-lb-hickory-engineers-hammer-69240.html
Ah the proverbial "bigger hammer" AKA a  BFH.
Hit it with a hammer first. If that doesn't fix the problem, then try something else. (Not to be used as a marriage 'rule of thumb' nor when raising a puppy).
