February 11, 2026, 09:26:26 am
Juki 563 rats nest when reversing
Started by Therapy, August 26, 2014, 02:58:01 pm
Therapy
hello folksI have a Juki 563
everytime I reverse to back tack I get a rats nest  on the bottom of the material
   is is it the tension in the upper machine or the lower I don't know what to do
Juki 563
I don't know a whole lot about sewing machine repair but whenever I have a problem like this its usually something simple like lint buildup. Give it a good cleaning, Make sure there are no extra threads wrapped around the bobbin mechanism, check to make sure its threaded properly and give it a good oiling.
Therapy
it's probably something as simple as that
I will take a look and clean it thanks
Juki 563
I operate a Consew 226 at work most of the time and it can be fussy if I don't press the reverse lever all the way down. Just sayin'.
Had some more ideas, if the needle is bent or has a bur it can mess up the stitch. Some fabrics like micro-fiber can also be fussy with the stitch.
Therapy
 I will make shere the  reverse lever all the way down
and check the needle
hay maybe i have the wong size needle
ill check thanks  Mike H
Juki 563
