February 11, 2026, 02:45:33 pm
Help....heat sealed t-top
Started by regalman190, June 16, 2014, 08:14:05 am
Hi all. Quoting a huge t-top and the client wants it heat sealed not stitched. Any ideas on how I can get this done or where?
In my area there is a company that makes banners and they have a heat sealing set up.  Boss used them a lot for awning work and my recollection was that heat sealing worked like a charm on Stamoid!  The canopy I made for our deck was heat sealed (Sunbrella) and we used it for 8 (?) yrs. and there was not even a hint of weld failure on it.  It's since been recycled into a canopy for the deck of a good friend and is still going strong.
I'd start with a local search for banner companies or larger awning fabricators.
Old sailmaker
It needs to be a rf sealing machine. The shop i was running before i retired I had 15 of them. I am surprised sunbrella sealed although stamoid will be no problem. Not sure who in private industry has one but awning companys should and if not call Kabar or Thermatron and they should be able to tell you someone close who would probably do it for you. Whoever does it for you would need some extra material to set the machine up for you as well. Hope this helps, any other questions about radio frequency sealing machines just ask. Craig
There are a num er of 80 inch cor in sunbrella
Thanks. I found a local shop that does it. The materiel will be Weblon.
