January 30, 2026, 01:40:36 pm
metal tack strips
Started by seatbuilder, February 24, 2014, 09:41:25 am
seatbuilder
February 24, 2014, 09:41:25 am Last Edit: February 24, 2014, 09:51:31 am by seatbuilder
Hi everyone. I have a pile of metal tack strip pieces, I was wondering if anyone has come up with a way of attaching two or more pieces together so they don't have to be thrown away? I find limited opportunity to use these small strips.
On another note. I ran out of plastic covers for these strips and didn't have time to wait for delivery. I put 1" masking tape on the back and folded it over. Lies flatter than with the plastic and leaves no raised marks.
Seatmaker
I was going to say that I use the plastic sleeves to join small pieces together. But other than that, I don't know of any way to join them.
I usually throw small pieces into a box, and use them on short runs when I can. Sometimes you can staple them to the back of a wood, or covered panel.
Something else I do. When I break off a metal nailstrip, it leaves a sharp edge. I use the grinding wheel to smooth it off. This way, I can use it without a sleeve if I need to.
I've done the masking tape thing a lot. Sometimes, the plastic sleeve is too thick for certain areas.
seatbuilder
Thanks. I think I will try epoxy and a splint. Sounds weird but Industrial plastics says it will work.
I never thought of using the plastic cover to hold them together. I will give it try.
scott_san_diego
I have used a cardboard strip to go on top of the metal tack strip with masking tape to hold it in place.  Works great.
You can also just place them together and use it that way. As long as they are in line it works fine. I find the plastic covers are thick but I do use them in Florida fearing rust. Never used them up north though. With the plastic sleeves it is easy to add like Sofa says.
QuoteWhen I break off a metal nailstrip, it leaves a sharp edge
I was taught (and therefore have always) cut mine with tin snips. If you have the points facing past the bottom jaw the top side will be burr free. I have on occasion nipped the corners off after a cut to avoid a sharp corner.
Save them. Some day you will get a job that will require a whole bunch of short tack strips.
4 tacks or less i throw away. I stack them in the plastic to use them up.
