February 11, 2026, 11:32:23 pm
stretchy fabric
Started by crammage, October 03, 2013, 12:04:09 pm
I think that Gene is having another one of his "Senior moments".
I think he meant fabric adhesive.
Such as:
http://www.walmart.com/ip/Aleene-s-Specialty-Fabric-Adhesive-3pk/21670444
I'm going to try that next time I have some cantankerous fabric.
My senior moments are starting to connect with each other and are slowing becoming one long NOW moment.
Sorry for the confusion. It is indeed fabric adhesive of which I applied a small bead around the edge and then spread it out with my finger.
Dede
Thanks, Gene! Something like Rowley fringe adhesive?
...and inside or outside the seam allowance?  THANK YOU! Okay, enough with the smilies...
West Village Studio
www.workroombuttons.com
Rowleys is exactly what I use.
DDandJ
SofaDoc, I have a cutter very similar to the one you have.  I believe mine is called a Birdie.  I got it when my the sewing factory my dad managed closed.  I tried using it a while back but the blade is dull.  Wouldn't cut hot butter.  Wonder if it takes the same blades?  I will say that the blade is FAST.  I'll have to be careful and not lose a finger.
Do you use it on all of your cutting or primarily just welting strips?
Jeremy
Quote from: DDandJ on October 10, 2013, 09:04:37 am
I use it as much as possible, mainly to save wear and tear on my hand. A few years ago, I started getting numbness in the thumb of my cutting hand. Since I've been using the rotary cutter almost exclusively, the numbness has decreased quite a bit.
The only time I still use scissors, is for more intricate inside corner type cuts that the rotary cutter can't achieve.
The Allstar cutter has a built-in blade sharpener. I'm still using the same blade that came with it. The blade is small, an well-protected. You couldn't cut your finger if you tried. The downside is, it really isn't made to cut more than 1 layer at a time. Sometimes I will fold fabric over and cut 2 layers at once. I can tell by the sound that it is putting a strain on the motor.
If your Birdie is more of a big industrial model, it may be too big to use as a substitute for scissors. If not, you should be able to locate a replacement blade.
