January 31, 2026, 03:33:41 am
Need to make thin garden cushions.
Started by Grebo, September 09, 2013, 09:42:53 am
Thin garden chair cushions ( tye on type )
With zippers to remove the foam for washing.
These are only 1" thick with binding. The backs are 56cm high by 47cm wide & the base is 43cm deep by 47cm at the front, they tapper down to 43 cm at the joint in the middle. Like a waist.
I am in two minds wether to make two separate cushions then join them in the middle, or have the front piece as one with the back/base pieces separate. for the zippers.
What do you recon is going to give the best finished result. I need to make 8 of them.
Ta
September 09, 2013, 11:14:06 am #1 Last Edit: September 09, 2013, 01:29:36 pm by Mike
Iuised sunbrella. On my deck chairs. No zipper   And 2" foam. nIce thing is after a florida summer thunder storm the cushion is t all waterlogged.  Mesh back too
http://i782.photobucket.com/albums/yy102/Mike8560/Upholstery/photo_zpsec466c3e.jpg
Are they going to be outdoors in the blazing Spanish sun 24/7? or will they be undercover ("garden" rather indicates the former).
Mike's idea of using mesh on the back if you opt for the zips in the back and a one pc. front is a great one.  I've used awning weight acrylic (marine canvas weight) for cushions and it's performed well for me, but I don't have the sort of sun you have in Costa del Wotsit.  I've also used the furniture weight acrylic and really like that for cushions on a porch or under a canopy.
Use the open cell foam! it's "the balls" for outdoor work.  And it comes in 1".
I say Garden, but it's actually for chairs on a sun terrace.
Customer is very 'fussy' ?  Cushions will only be put out immediately before use & put away straight after.
They only visit from time to time, so they are not going to really get much use.
I am using awning weight canvas, purely because it's the colour they want ( bright yellow with white piping) !
So I think the one piece front will be the way to go then. I was just going to do canvas all round as they certainly won't be getting wet.  ::)  Not unless something gets spilt on them that is.
Thanks
