February 02, 2026, 06:41:31 pm
EZ Glue Gun
Started by Virginia Taylor, June 10, 2013, 08:10:18 pm
Virginia Taylor
I can't get glue gun to spray ,  it just blows bubbles.  does anyone have any ideas how to get it to spray?
Virginia Taylor
All American Etc Upholstery
Jacksonville, AR
If you can't adjust the nozzle because of adhesive build-up, take it apart and soak the parts in MEK. Use a small wire brush to scrub the old glue off.
After you get all the parts clean, put it back together and see if you can adjust the height of the nozzle for a proper spray.
Virginia Taylor
Thanks I will do that,, Also I'm using Weld Wood Glue is that ok.
Virginia Taylor
Jacksonville, AR
The vent hole is plugged if your blowing bubbles. Like sofa said clean it. Weldwood will tend to clog the guns faster than a foam adhesive.
