February 12, 2026, 07:39:24 pm
Tuff day for me
Started by Mike, May 08, 2013, 04:14:26 am
May 08, 2013, 04:14:26 am Last Edit: May 08, 2013, 06:25:39 pm by Mike
I have to go sew a ten foot bimini them pattern and sew a smaller bimini for a pontoon then a connectir between the 2 and boots  i bent the frames yesterday but was short one frane. After i get thst bent s d sll done i have togo install.    Uggg.
NDAV8R
   Ya, I here you bro...I'm installing an air ambulance conversion (2 person gurney) in a late model Pilatus aircraft, and part of my job is to install LED flood lights on the cargo door. I use FAA approved panel board called Kydex (ABS plastic that does not burn) for the LED mount panel and cut it TOO short on one end after I did 3 hours of riveting the mounts in place. Ugggh!!!
   Fortunately after calling the Factory of the very expensive Kydex, I can use ABS bonding adhesive that plumbers use to weld the pieces together. The repair will take an hour vs buying new Kydex and re-reviting before I cover it.
Gale.
Some days its hard to get on a roll.
finished at 5 then had to go install I didn't get over till 7
