February 16, 2026, 07:45:14 pm
Pfaff Feet
Started by baileyuph, December 27, 2012, 06:25:47 am
For tight places in a flat fell type walking foot (1245/545 etc.), what are you using on a Pfaff?
Mine are wider, something one would use for binding applications (not the best for tight turns and places).  If you have something around 3/8ths wide (both feet combined), mind posting the part numbers  (indicate if numbers are Pfaff or whatever)?
Are you talking about welt feet? You can get them with a toe on the left side only:
http://www.ebay.com/itm/PFAFF-WALKING-FOOT-SINGLE-TOE-WELTING-FEET-SET-/300405692318?pt=LH_DefaultDomain_0&hash=item45f193179e
And for non-welted sewing, they have zipper feet with the toe on the left, or right side of the needle.
I'm not opposed to buying cheap feet from E-bay stores, and grinding them to suit special needs.
QuoteFor tight places in a flat fell type walking foot (1245/545 etc.), what are you using on a Pfaff?
Small flat feet in a standard walking wood style.
Isn't that technically referred to as flat fell?
Anyway I do several hundred custom covers a year for a customer and a narrow standard flat fell would speed my sewing time.  Even a little bit times the number I do is significant.
I might only need the pressure component, my needle foot is probably narrow as I might find.  The pressure foot I use is for sewing binding on carpets (i. e. auto carpert and vinyl binding).
Don't know, I am looking for a listing of feet for the Pfaff walking family.
Maybe I can do that after work today?  Don't know, got an order for more of these products and anything to improve efficiency will help.  I am also looking for  digital pattern equipment, drawing/cutter, which would also speed up and improve the operation.
