February 13, 2026, 05:28:35 am
Pfaff Repair in Phoenix
Started by BigJohn, November 29, 2012, 06:56:04 pm
BigJohn
My 1245 Pfaff is out of time and I'm looking for someone in the West Valley of the greater Phoenix Area to do repairs, anyone have a name and number?
                                                     Big John (and getting bigger)
Eric
November 29, 2012, 07:06:41 pm #1 Last Edit: November 29, 2012, 07:07:46 pm by Eric
Irv Wilke (Four14-25four-3528) (800-932-0507) He works for Henderson sewing machine.
He repairs my machines for me. However he lives in a
Arizona.
Give him a call.
Eric
zanepurcell
big john, how handy are you? You could probably do it yourself. what are your symptoms?
If it's only timing ; I'm with Zane. No disrespect to our two machine gurus on here, but out here in the sticks , that is just operator maintenance.
If you've been so unfortunate as to throw the feed dogs out as well ---then it warrants their talents. If it is just the hook/needle alignment---we should be able to get you to get you going in short order.
The machine is irrelevant. A has to be here when B gets to there with C in this position. We'll find the set screws to adjust that equation.
John:
if you have a few mechanical skills then give Bob a call and see what he says. I am not sure about Pfaffs but I time my Juki and Chandler myself. It is a very straight forward job. Bob talked me through the first time over the phone. After that I was good to go.
Give Bob a call and see what he says. You know him well so I am sure he will help you out.
BigJohn
I timed my old Singer using over the phone instructions from Bob Kovar and Son, and I may just try it again. I only wish I was within reasonable driving distance to Bobs shop, I'm sure he'd have me in and out in minutes! It looks like I'm going to have to mothball the Pfaff for a while as I concentrate on some remodeling, decorating, and landscaping projects around the new house. I've been taking advantage of readily available day laborer's available at the local "hiring corner" just down the street from the Home Depot. My next project is installing a new drip irrigation system in anticipation of planting palms, cactus, shrubs and ground cover in my bare back yard along with a small patch of irrigated grass for my Terrier "Rosie".
