February 12, 2026, 09:43:29 am
Christmass fastners in marine work
Started by Mike, August 19, 2012, 02:17:28 pm
I've got some side panels on my boat I will be reupholstering and the side. Laming pads and two of the boarder backdest pads have theese to fastnen them alot of then broke taking then off.
I seen theese at Miami
http://www.miamicorp.com/default.aspx?page=item+detail&itemcode=AU12759&catlist=442
Is the flat washer thing on the inside and push the stud part through the plastic panel board then into the hole in the boat. I've never trusted using theese so it all new to me and I though I'd try it
I don't this my pad have the washer as I havnt removed the. Inky get but did have some break on and can't tell if there was of not a flat
Piece inside?
You have the idea Mike,
  The fastener goes through before you upholster the panel. There are many many different sizes so make sure you get them the same shaft size and length that you need.
I've seen lots of them on Intrepid coaming pads.  They work like a champ.  Love em!  So much easier than bolt-through if the part doesn't have be structural or hold weight.  I like the double ended ones like this.
http://www.clipsandfasteners.com/Double_End_Xmas_Tree_Retainer_p/a20866.htm
Pretty sure Miami carries them.  Auveco manufacturers a very nice selection of panel fasteners.
Miami Mike
Mike we have these X Clips. Double ended
http://www.miamicorp.com/default.aspx?page=item%20detail&itemcode=XCLIP7
I have to give them a try mike is there different diameter shaft size   To fit my holes perhaps there all one size fits all.
As I recall, they require a 1/4" hole.
