February 23, 2026, 11:11:26 am
How to remove, pine resin from windows ?
Started by Grebo, June 23, 2012, 12:03:07 pm
Hi, I have gone & bought another trailer tent ( pop up) .
I went out to buy a camping fridge & this guy happened to have a TT almost identical to the one I already have but a good few years younger & he didn't want much for it.
Hmm, expensive fridge eh !
Well........
Now I have had a good look at it I find it has been pitched under some pines & got resin on half of the awning roof & somehow on most of the awning windows !
I have brushed, vacuumed & scrapped most of it off the tencate canvas roof. At least it doesn't leak.
But not sure how to attack the windows, they are made from a clear 'vinyl' that is so much thinner than anything we use on the boats.
Any suggestions that wont melt the windows.
Just for Gene  ;D
A trick to getting pine sap off your hands is to rub with butter or olive oil. It rubs off the sap then soap and water do the rest. I don't know if it'd work on windows.
Lighter fluid is a cheap fix for anything sticky.
I don't think it will harm the plastic windows. (totally wrong face for Gene  :o)
CKKC
The hand cleaner "Goop" will take a lot of stuff off without scratching!
June 25, 2012, 12:57:39 am #4 Last Edit: June 25, 2012, 12:59:03 am by Grebo
Thanks, will give olive oil, soap & water a try first, lighter fluid last I think.
Haven't got 'Goop' is swarfega the same thing ?
T'anks.
ajlelectronics
Try Vodka! seriously. Otherwise, wander into a body shop and get some pre-paint wipe. There are two types, spirit based and alcohol based. Hed some of each. Use the spirit one first, then clean up with the alcohol one.
CKKC
Quote from: Grebo on June 25, 2012, 12:57:39 am
T'anks.
I've no idea what swarfega is!!    Goop is the hand cleaner used by mechanics to
cut the grease and oil off their hands.
Carol
Quote from: CKKC on June 25, 2012, 05:48:59 am
T'anks.
Carol
Yes so is this, sort of thick green gooey jelly stuff ?
SHHR
Since this topic came up, How about pine sap from fabric. We have a line of pines that surround our property. My daughter went outside and set under one to read for a while then came in and plopped down on the couch to leave a big gob of resin on the cusion. My wife removed the cover to wash before asking me and it's still there, just not as noticable.
Kyle
CKKC
Quote from: Grebo on June 25, 2012, 08:32:54 am
T'anks.
Carol
Goop is white but I have seen other colors.   That is pretty much the description!
June 25, 2012, 06:03:33 pm #10 Last Edit: June 25, 2012, 06:05:18 pm by byhammerandhand
Goop is one of the various emulsified or gelled solvents (d-Limonene and/or mineral spirits)
http://goophandcleaner.com/
not to be confused with "The Amazing GOOP" that is a gelled contact cement.
Very similar is Go-Jo
http://www.gojo.com/united-states/productsearch.aspx?cpn={C28D86C6-DBB7-41E4-91DF-FE911E7BB7C1}
(when I was in high school, I used to degrease executive jets with this stuff)
or Fast Orange
http://www.permatex.com/brand_fast_orange.htm
Just don't get the formulations with pumice in them -- too abrasive.
FWIW, many restorers use GoJo or Goop to do a quick clean up of wood,  Work it in with a rag, let sit a minute, wipe off with a clean rag.   The oil that remains is similar to furniture polish.
GooGone is a bit stronger solvent, I use it to clean off adhesive residues.
Goof-Off is xylene and even stronger.  May damage some finishes or paints.
UPDATE.
I had great results with Eliminador de adhesives from Auto Glym.
