August 10, 2026, 12:08:24 am
Contour Chair
Started by baileyuph, May 28, 2012, 06:22:04 am
This might be interesting to run by the professional furniture readers:
Situation is a customer dropped off a contour char, shaped like a curved banana if you will.  There are rows of buttons used from the top to the bottom.
My basic thought is, after noting that the weak point of the previous job was where a persons rear sits, more or less in the center of the contour.  Over the years I have noted there are a few different ways of covering the curved area.  I would like to design the upholstery so it will last, merely covering the seating area by vertical and horizontal seams and button tufting at the intersection of these seams, in vinyl, will not and does not hold up.
Consequently, I am looking for experiences with this issue, anyone with an idea please present it.  I have thought of diving the curve up into three cushions with pulls to the back side for stapling.  That would take the tension off an integrated button tufted situation, as was presently done on the failed existing cover.
Any experiences in combating this issue?
Does the fatigued area currently have no horizontal frame support that you can staple a pull-seam to?
Would adding more springs be an option?
