January 26, 2026, 08:29:14 pm
pedicure seat
Started by lruthb, April 19, 2012, 01:04:29 pm
lruthb
This is a repair on the seat. The owner stated that their customers slide down on the seat. I was thinking that maybe tuck and roll might help. I am open to any ideas you might have.
Thanks
Lynn
i dont remeber wha the name was but ski doo, bobadier had a special vinyl on there sled seats to give good grip
Virginia Taylor
MAybe              All Sport Tacky
Virginia Taylor
All American Etc Upholstery
Jacksonville, AR
April 19, 2012, 04:57:25 pm #3 Last Edit: April 19, 2012, 06:01:38 pm by kodydog
Just a thought. I can't tell you how many pedestal type chairs I've done where the seat is attached to the pedestal backward. Leans forward instead of backward.
Only other thing I can think of is build up the padding on the front of the seat.
One other thought. I just repaired a cheep office depot type chair that was leaning forward by adding spacers between the rocker mechanism and the bottom of the chair. I loosened the front two screws and fabricated a piece of 1/2" plywood to fit. I then had to add longer screws to reattach the base to the seat bottom. Worked like a charm.
If the structure is installed correctly, then it's most likely the foam that has become wedge-shaped, tilting toward the front. I'd replace the foam.
