February 14, 2026, 11:04:45 am
PFAFF 238 needle sizing
Started by Faster_K_Yote, March 13, 2012, 04:10:08 pm
Faster_K_Yote
The original needle that came with this machine are as such (see attatched)
http://s805.photobucket.com/albums/yy336/Faster_K_Yote/?action=view&current=PFAFF238ORIG001.jpg
Not sure what any of it means and could use some clarification.  What I really need is a needle stronger and can handle V69 thread.  Typically sewing sunbrella.
Thanks
Brad
Sailing - Like being stuck in a broken down bus in the desert.
Faster_K_Yote
Not even sure if the needles that came with it are the right ones?
Brad
March 13, 2012, 08:02:56 pm #2 Last Edit: March 14, 2012, 06:30:09 am by Gregg @ Keystone Sewing
Correct needle system, 134.
I would go with a size larger, NM110/18 or a 125/20 for seaming work.
Most sailmakers would be at a size 125/20.
Faster_K_Yote
When I look at the needles I have there is 134 (R), is that the needle system?  The line below it references 135x5, what does that tell?
Faster_K_Yote
Found this from the schmetz site.
S134R Needle System
CANU: 20:05 1
134 (R)
135x5
SY 1955
DPx5
System S134R is generally used in single needle lockstitch industrial sewing machines. It is also known as 135x5, 135x7, 135x25, 1901, DPx5, and DPx7. Standard sharp point. Available in sizes: 10, 11, 12, 14, 16, 18, 19, 20, 21, 22, 23, and 24. Needles are sold in boxes of 100 only. When ordering please specify the number of boxes, not the total number of needles (i.e., quantity of 2 = 200 needles).
I'm guesing I need this needle size 18 then greg?
Gobs of info on needle sizing here, will take me a bit to wade through it.  Thanks for the help.
Brad
March 16, 2012, 09:14:27 am #5 Last Edit: March 16, 2012, 09:18:20 am by Gregg @ Keystone Sewing
http://keysew.com/Webpages/DemoImages/SchmetzNeedleChart.jpg
See this image, since we are talking about Schmetz.
