February 15, 2026, 07:17:44 am
help guys need to make a top for my skid loader with windows
Started by jim fuchs, November 02, 2011, 10:29:29 am
jim fuchs
what gage should i use 40 im using top gun .  hows  the best way to do the windows edge can enyone post some pics  i also will need to make a door that nees to be stiff got eny ideas . do i just cut a hole out  in center and fold the edge over and sew to plastic . or make strips and sew around them and then sew it all together to make it slip over top . jim was going to use lexan but its way to high priced .
Do you have. Frame or are you going to make one
od use 40g window vinyl. Are you going to need to look throught the vinyl to drive?
Anyway I'd face out ( trim around the window ) with a 2" strip of the matching canvas to suppert the edge of the window. As far as a door  to make a frame I'd use square or round tubing  and sew pockets thT wrap around the frame and zip onto them. A pic of what you have to work on would help. I did a riding. Snow lower on e with a top and front window.
