February 10, 2026, 11:18:22 pm
Angle Binder
Started by jsquail, September 14, 2011, 11:20:04 am
jsquail
I read a thread on here about angle binders not too long ago so I ordered on from Gregg Monday. I have to say its the best binder I have used to date. Goes around corners and turns with ease.
And thanks to Gregg too! Once received, I had it on the machine minutes, adjusted, and binding like a champ!
Gloucester Canvas
www.gloucestercanvas.com
Jsquail,
That's really awsome, glad it worked out well.  I think the binder along with the custom install is the way to do it.  It gives us the best chance to work out of the box.  What do you think of the large thumb screw?  Do you use it?  It's not cheap, so I don't want to send parts nobody is going to use.
Again, I come here for feedback, and always want to hear both good and bad so i can be on target with what people want and what works.
jsquail
I used the thumb screw instead of the dark screw. It made more sense to me if/when  I needed to remove it and get it out of the way.
I must say it really is the hot ticket for binding. I did a lot of binding with that susei swing arm binder. Curves and corners on the swing arm are a PITA compared to the angle binder.  I was impressed that I didnt need to slow my stitch for curves. Definitely a time saver. Wish i would have bought one sooner.
Gloucester Canvas
If not too much trouble, could you show the binder set up on your machine and even a picture or two of what the results are on inside curves.  Examples, of the binder output, is the idea.
Thanks in advance,
jsquail
can do. I will sit down later today and run a few test samples through the binder for you and take pictures.
Gloucester Canvas
Quote from: jsquail on September 14, 2011, 04:22:22 pm
OK, good to know.  The black screw is good if you want to swing the binder out of the way, with the low profile.  Thumb screw is good if you want to remove or install quickly.  That was the idea, anyway.  Thanks for the feedback.
DB, I'm too much of a ham not to show off my pics, you can see them on this item's product page;
http://store.keysew.com/sewing-parts-and-accessories/460-custom-angle-binder
That said, I'm offering an angle binder for turns and curves...but I didn't show any images of turns or curves, EXACTLY what people want to see.  Hmmmm, maybe  if jsquail's images look good, and with his consent of course, they will show up on Keystone's website!
Nice looking binder!  I like how it keeps the bulk of the device well away from the needle giving room for the operator to handle the fabric and see what's going on.  Does it handle double-fold Sunbrella binding?  And are there a set of feet and/or feed dogs that are required to go with it?
jsquail
Quote from: JuneC on September 15, 2011, 07:21:25 am
Yes, with no issues.
Gloucester Canvas
JunceC,
This was part of the up front conversation jsquail and I had up front before his order.  I sell this two ways, as per the website, allow me to quote...ummmm myslef, LOL;
460B Custom angle binder, 1/4" mouth opening, for tape and braid, made in the USA, custom install machine specific so binder head is close as possible to STOCK presser feet and feeder without hitting
***Kindly advise machine model at Checkout "Comments / Delivery Instructions"***
***Custom binder with parts (feet, feeder, needle plate) for custom install, specific to your model, contact for price quote, kindly advise model machine to be installed***
Now, no two people work the same, and not all shops are the same and have the same equipment, but in jsquail's binder for his work works well with stock feet.
For others, who have a machine they can dedicate to binding, it may be best to use a machine with custom feet, feeder, and needle plate.
jsquail
Links below. Its Blue sunbrella. The white is the acrylic 2 edge turned from Rochford. Its the same as sunbrella 1" double edge turned and it may be sunbrella, Rochford just doesn't call it that. The curve has a Diameter of 6.5 inches. The first curve i did on it was a 1.5 inch Diameter and the sunbrella binding doesn't want to lay very flat, but that is due to how tight that curve is. The binding will only stretch so much.
http://i1139.photobucket.com/albums/n549/G_Canvas/6c401f72.jpg
http://i1139.photobucket.com/albums/n549/G_Canvas/7e4bb397.jpg
http://i1139.photobucket.com/albums/n549/G_Canvas/4e78a321.jpg
Gloucester Canvas
jsquail
Gloucester Canvas
everytime this topic comes up I tell you this binder is the ticket !! :P
I know (from past experience) the right angle binder is the solution to curves but I'll be damned if I can get mine to work properly!  I have to box it up and send it back to you, Gregg.  I can't get mine to work worth a tinker's damn and lord know's  I've tried, lol.  (e-mail to follow and I'll gather up some fabric samples for your shop's use).
It looks to me as though the stitching is very close to centre of the binding in jsquail's shots.  I immediately wondered if the stitching allowed the raw edge of the glued and folded allowance of the binding to be visible outside the stitching.  I can't tell from the pictures.  (a "no-no").
I am an advocate of the thumb screw installation, too.  I can go for days/weeks without using a binder (as is evidenced by how long I've been farting around trying to get mine to work, lol) and like the quick installation and swingaway feature when working on a project that requires binding.
