February 13, 2026, 07:40:41 pm
Where to get a new feed dog for Juki DNU-1541S?
Started by JanChristian, August 24, 2011, 09:22:26 am
JanChristian
I purchased a right angle binding attachment that came with a new needle plate and feed dog. Unfortunately, the feed dog isn't the right size. It was too long so I reworked it with a dremel but it still isn't right, it's too tall. I want to get a new OEM feed dog then grind down the front so it'll work with the new needle plate so I contacted the place from which I got my Juki and they said a new feed dog is $300! I couldn't believe it... Do you know of a cheaper source?
The set I got looks similar to this except the needle plate is different:
August 24, 2011, 10:38:26 am #1 Last Edit: August 24, 2011, 10:46:33 am by Gregg @ Keystone Sewing
Genuine Juki OEM for DNU-1541S, part number 214-10303, FEED DOG (6X2.5) is $42.70 plus shipping.
Thats nearly a 550% savings!
One you got is for Consew 206RB series, and Juki DNU-1541 series, as you can see for yourself, different, but do look the same.
You can find my contact info. in my profile of you would like to order.
JanChristian
haha thanks Gregg, I'll send you an email right now
I looked at my parts list and it shows a part number of 400-19910 for the "FEED DOG (6x2.5)". Is this one different from the one you listed?
August 24, 2011, 01:49:47 pm #3 Last Edit: August 24, 2011, 01:58:24 pm by Gregg @ Keystone Sewing
Quote from: JanChristian on August 24, 2011, 12:24:13 pm
Just double checked...the part number I have listed is correct for Juki DNU-1541S feeder.
I sent via email parts book so you can check my work/see for yourself.
Your number 400-19910 IS a good Juki number, but not sure for what (current Juki price list has listed over 59,000 parts).  It could be for a different Juki machine, or a special application feeder for the DNU-1541 series.  Not sure, would have to look.
But for certain part number I provided is standard stock feeder from factory that would have come new out of the box with DNU-1541S machine, for sure.
Jan,
Just checked with Juki, was on the phone for about 15mins., the number I gave is correct, and has been for some time.  New item is a 'special item' as per their online description.  No idea what makes it so special other than the fact that it's a $300+ feed dog.
