February 10, 2026, 08:06:56 pm
S ones for grebo a t top
Started by Mike8560, July 20, 2011, 01:19:03 pm
After I cut to Shape I cut 4" strips of matching canvas and fold them in half and bind the to the edge on the underside
http://i782.photobucket.com/albums/yy102/Mike8560/1a569961.jpg
then I sew the inside edge down and make mitred fold at the corners
http://i782.photobucket.com/albums/yy102/Mike8560/40e7a6bd.jpg
the. I mark. For my grometts at 4" intervals   Latky my supply of self piercing don't peirce and set well so I precut the holes with a common sence cutter
then set themeih my press
[IMG]http://i782.photobucket.com/albums/yy102/Mike8560/1ac44671.jpg
nice one Mike, I so wish we could buy matching binding here
it looks so much better than centerfold sunbrella.
July 21, 2011, 12:56:16 am #2 Last Edit: July 21, 2011, 12:59:02 am by Grebo
Thanks Mike, better late than never  :P, Just Kidding. :-*
Fitted it last Friday.
Due to the need for a 'dull' or dark underside & lighter top it ended up as a double layer of stamoid heavy.  ??? What a bear to punch through. Plus it needs to be super strong as it is taken off & moved in a shipping container from time to time. I matched the binding to the underside, well it had to be one or the other !
4" between hole centres, as you said  ;) size 2# grommets & 5mm cording. No extra reinforcing as the stamoid is pretty tough stuff.
The lumpy bit at the end of the stitches on the back is now under an antenna base  :D.
not bad at all Suzi, did you ever think about doing canvas full time  :o
Rich ;D
You can go off people you know Rich  :P
Ah you had I'd made suzi it wasn't e en on the boat
I had to I
climb all over mine
did the upholstery too
Yes  ;D I did.
Mind you it's a long way off the ground now, just been put on the boat. Get a piccy when I get chance.
I lace awnings/canopies the way you lace your tops, Mike.  I find it's easier to keep tension on the line with that pattern than it is with a simple spiral.  But I would try to lace it so the "run" of line between grommets was on the underside and protected from the sun.
With awnings/canopies I start in the center of a run and work my way out the corners (which are held in place with a cable tie/two).  Once I have the canopy in place and square to the frame I am easily able to go back and tighten the lacing more by simply putting a hook over the "run" of the line and pulling it down snugly.  I work down the line to the corners and am always amazed at how much slack I can get out of a top that way.
The awning trade used to use cotton line because once it got wet it would shrink and tighten the canopy even more... but you have to replace it every year... not so with polyester line.
Ya I run mine on top.  Mostly
cause that' ls the way it was.  I suppose so the bottom is cleaner looking from in the boat.  And yes I start front middle and when I go back to tighten you end up with quite a bit of line left over.  I usualy use Black Wichita las longer nut I couldn't get it
