February 16, 2026, 03:32:56 am
vinyl top for older cadillac
Started by Uncle Lar, June 16, 2011, 04:12:52 pm
Uncle Lar
Hey everyone.  I've been doing auto upholstery full time for a year and a have,  and its time to cross a new bridge.  I have a potential customer with a 78 cadillac sedan deville, which needs a new vinyl top, which up to this point I have not done.  The vendor I get convertible tops from does not have an exact fit top for this car, just the universal ones, which probably isn't a big deal.  However, the car has a very light green vinyl top, a color that they don't have a similar match for.  I know that the vinyl for roofs has a harder surface than marine vinyl, but the thought has crossed my mind to use the marine, as the car is a family heirloom and won't see use other than occassional weekend driving.  In addition, I can get close in the color match department.  Still I question if this is a good move, in regard to general durability and holding up to sunlight.  Also, I would have to deal with the stretch of the vinyl and how that would play in laying the seams straight on the roof.  And, if I sew this together, will I need to somehow seal the seam?  Or should I try different vendors? Now, what are your thoughts?  Thank you!!!
I have done a lot of vinyl tops over the years, but I have never tried one using marine vinyl.  The replacement tops have a fuzzy backing that helps the glue grip the vinyl, also the replacement tops can pretty much stretch in any direction, which is important getting the vinyl to lay down wrinkle free on the sail panels.  As for color matching, are you trying to match the color on the visible surface, or have you removed some molding where the top was not subjected to direct sun?  The top underneath a molding will be closer the the original color than surface's exposed to the sun.  Even it you had the exact same vinyl and color, it would be different because of the dye lot changes.  If it was me, I would live with a little different color than try using marine vinyl, but others may chime in who have actually given this a try.
phoenix
Call Kee Auto Tops...they can make any top,any dimension.they may even have the color.
Uncle Lar
Thanks for the responses.  I think I need to hold off for the right vinyl for the job.  I have used the vinyl that is tucked under the trim as reference for a close color, as  most of the top's color is really baked and oxidized.  I have contacted kee, and they are hopefully sending me samples of a couple somewhat close colors, at least by looking at their website.  I say hopefully because the colors are actually discontinued, but they were going to send samples if they had enough to make a top, or let me know if they didn't have enough.  Anyone know of other vendors who deal in vinyl tops?
Miami Mike
June 20, 2011, 11:41:21 am #4 Last Edit: June 20, 2011, 11:45:32 am by Miami Mike
We make vinyl tops, just need the year make and modle . center or double seam. french seam around back windows too. Also we make for tops for the Limousines. the like is for the vinyl we stock>>> first few pages are the vinyl topping.
You will hace to copy the full link>> Sorry
http://www.miamicorp.com/default.aspx?page=item search results&SearchSource=Pagination&SearchType=AND&forcePrice=False&forceAvailability=False&OrderByColumn=&OrderByDirection=&SearchKey=SK23617PM&CurrentPage=1
