July 21, 2026, 07:02:48 pm
Rotary Cutters
Started by Chuck D, March 23, 2011, 05:54:48 pm
Chuck D
I remember the calouses my dad had on his hands from using shears......in fact I have a couple myself. I have been using a rotary cutter for a couple years now but as of now I still sharpen my blades with a rig I made and use with a hand drill. Does any one know of a sharpener for 60mm rotary blades? One that's not made of plastic and made to last.
I thought the sharpeners were built into the machine. If not, couldn't you use a sharpening stone held to the blade while it's spinning without removing it?
seamsperfect
Quote from: Chuck D on March 23, 2011, 05:54:48 pm
cardboard grinding wheels work great on knife blades. Might look into them, they attach to your grinding motor.
Kevin
http://www.razorknife.com/abproducts.htm
Ihavenoname
Your talking about a hand held push cutter right? The only one I know of is the cheap plastic sharpener.
Quote from: Rich on March 24, 2011, 05:01:59 am
All the cutters I can think of are self sharpening.  That doesn't mean that someone removed the self sharpener along the way somewhere, or never installed from the begining.
Chuck D
Sorry, I didn't clarify that I was referring to a hand held rotary cutter. My bad.
hdflame
I use a 60mm Olfa cutter all the time.  For cutting out material and vinyl, I'd rather use it than my shears.  I bought this cutter.  http://www.usasharpeners.com/
It works for 45 and 60mm blades.  So far I've only used it one time.  I didn't get the cutters razor sharp like new, so I've just been putting in new blades since I bought a bunch pretty cheap on eBay.
I've been saving the dull blades and will give it another shot later.  I think it'll work, I just need to spend a little time playing with it.
Bobby
www.sunstopper.biz
Several Old Singers
Elna SU
Older Union Special
