September 07, 2026, 08:19:22 am
Punching grommets through webbing.
Started by Grebo, March 15, 2011, 10:17:49 am
DBR what do you use ro cut the hole?   I've got  a had tool that punched the hole and it a bear to cut iwebbing. June I've found latly that self piercing don't cut? A d also no self piercing spur only the gromett is different as far as I cs. Tell so I winder why.  I space mi e about 4" on q t top q d install about 75 I hate using my bench press the arm really get tired
forsailbyowner
Hey June I got self piercing spur grommets from miami Mike. They work in the same press mike8560 pictured
Quote from: JuneC on March 22, 2011, 04:18:34 pm
A single t-top can take hundreds of grommets.
http://www.centuryboats.com/images/uploads/boats/2102IS-ttop.jpg
I have a floor-standing, foot operated, Stimpson.  Unfortunately, I don't have self-piercing dies for it so holes must be cut first.  I have yet to find self-piercing grommets with spur washers anyway.  No idea why the two concepts can't be combined.  You can either get self-piercing, or spur, but never have found both in a single grommet.
DBR1957
Mike8560 - I just use the Osbourne punch. If you're punching a hole just through
webbing it is a pain because the loose weave of the webbing allows it to conform
to the end of the punch. But if the webbing is sewn to fabric, put the fabric side down and it will "stiffen" the webbing and punching the hole is no problem. If you punch the fabric side first the webbing will distort.
It works for me anyway. I'm typically sewing the webbing to Sunbrella or vinyl.
Thanks for the info forsale. I've got spurs from miami.
I'll have to check the part number to see if theese were selfpiercing ?
You don't ha e the # do you ?
