February 05, 2026, 12:59:00 pm
Marine Carpeting Removal Issue
Started by baileyuph, March 05, 2011, 05:59:06 am
March 05, 2011, 05:59:06 am Last Edit: March 05, 2011, 06:10:40 am by DB
This is a general question as to what marine business people use to remove marine carpet, in a non pontoon boat?
In your business do you use a chemical to remove the glued carpet?
I plan to scrap, grind, or whatever, if there is not a cheap remover.
I read the post regarding pontoon boat, but this is carpet on fiberglass.
Thanks ahead,
I use my hands. Pull up the old stuff and hopefully it'll come away clean. Sometimes the pile pulls through the backing and stays stuck to the boat. Then a scraper or wire brush to remove any lumpy chunks. It doesn't have to be pristene the carpet hides a lot. I don't use any chemicals, well, aside from the glue.
SHHR
Just like peppy says, grab it and yank (the carpet that is). I did a bass boat last week, part aluminum deck part fiberglass. Most of the aluminum had the carpet pull away fairly clean. I just wiped it down and glued the new down. The fiberglass left some of the nap on it but a sharp scraper took care of it quickly. Be carefull using adhesive removers or thinners on the carpet glue as it will soften the fiberglass resin.
Kyle
