February 03, 2026, 02:52:55 am
Help - Keder and Awning Cord
Started by Mojo, August 31, 2010, 06:42:49 pm
I know who I am calling the next time I cannot find something. The Google Goddess. :) Thanks June. That looks identical to what came off the old awning.
Thanks PDQ. Now the problem would be figuring out what they call that stuff in the USA. :)
Thank you to both of you. :)
CKKC
Thanks Google Queen!!      That will help this newbie a lot.
They may not be the cheapest supplier - just showed up on page one when I did my search.  Google "sling spline" to see lots of suppliers.
Miami Mike
I have samples on the way to make sure it's the right stuff. I will let you know. I have a a customer in SC that I will show it to. He uses it a lot in the outside furniture.  If it's the right stuff, i should be able to save you. But waiting on the sample.
Not sure how big the sample will be, but I will send it to you as well Chris.
Good job June.
Mike:
If you can locate this stuff and stock it then your going to be Dah Man. :)
I just ordered 100 ft from the people June linked to but I would much rather buy from you if possible. I am trying hard to sole source if I can through Miami.
It takes approximately 80 ft of the spline material to do a Class A coach with 4 slides.
BTW Reanna at Recarsen sent me an envelope of tags for the Recacril along with a few dozen fliers to use in advertising.  That should get me started. I think I cleaned out Miami's supply. :)
If you can send me that sample then that would be awesome. if it is not the same stuff then I can send you a sample of what I bought.
Thanks Mike.
