February 04, 2026, 10:51:04 pm
Consew 206 Thread Controller
Started by go_hercules, August 24, 2010, 03:52:35 pm
go_hercules
Hi Everyone, I just joined the forum.  I bought a real nice Consew 206 RB-1 recently and have noticed a little problem.  The thread sometimes becomes slack enough that it jumps off of and falls under the thread controller.  That is the disc under the thread tension disk.  Anyone seen this or know what causes it?  Thanks a lot.
If everything else is correct, it can only be one of two things; either you are not threading correctly, or the thread controller is defective.  If the controller has "SEIKO" stamped onto it, then it's likely the original, and that's a good thing.  Most of the defective thread controller disks are aftermarket.
Try this first. When threading the thread controller, from right to left, pinch off the thread, say before you get through the spool pin, or soon after than.  Then, pull the thread straight up at 12:00, and the thread should 'snap' behind the hook finger on the thread controller.  This will prevent the thread from going out under the disk.
Let me know this this helps.  This is not a common issue, and can certainly be corrected.
go_hercules
Hi, you hit the nail on the head.  I was not pulling the thread up enough to click it in behind the little fork on the thread controller.  I just let it loop up through the spring.  I tried it like you said and it works great.  Thanks very much for the help.
Quote from: go_hercules on August 25, 2010, 10:10:15 pm
Glad I could help.
