February 01, 2026, 12:51:50 am
Exotics
Started by 69Mach1, August 22, 2009, 06:05:58 pm
69Mach1
Stitcher,
  Where are you getting that line from?
stitcher
The cover is made of NUVTEX VINYL and I purchased it from Three Rivers Supply, Co.  Homestead, PA  412.462.3900
The foam I use on Chopper seats is from Smooth-On Corp.  http://www.smooth-on.com/Rigid-and-Flexible/c10_1121/index.html I use a 2 part chemical mix  either 5lb or 10lb density.  I pour the foam over the pan and start carving away.  It is more work but it works Great!
And yes I use a plastic slipping agent over the foam to slide the cover on, on most seats.
Stitcher  ;)
hdflame
I noticed they had 4 different kinds of expansion foam and each one was available in 3, 5, 10 and 25 pound densities.  Which one of these do you use?
•FlexFoam-iT!® III - 1A:2B by volume - approx. 18X expansion
•FlexFoam-iT!® V - 1A:1B by volume - approx. 10X expansion
•FlexFoam-iT!® X - 1A:1B by volume - approx. 6X expansion
•FlexFoam-iT!® 25 - 1A:2B by weight - approx. 2X expansion
Also, what do you use to shape it?  Thanks!
Quote from: stitcher on September 26, 2009, 04:15:20 pm
Stitcher  ;)
Hey Stitcher,
Great site!  That Smooth-On site is really interesting.  I watched one of their videos of someone duplicating a bust.  I could see that stuff being used in a lot of interesting ways.
Also, what do you use to shape it, and what is plastic slipping agent ?  Thanks!
Bobby
www.sunstopper.biz
Several Old Singers
Elna SU
Older Union Special
UpholsteryJournal
Just had some new exotic, animal-inspired vinyls come across my desk:
Antigua and Serengeti from Boltaflex by Omnova. Antigua has a crocodile-embossed pattern and Serengeti is ostrich-embossed. Both are marine-grade. They're made with environmentally-conscious materials too, if that adds any value for your customer.  http://www.omnova.com/products/contractUpholstery/new_designs.aspx.
Also, the Celebrity line from Silver State has lots of snakeskin patterns, including rattler and scorpion! Kinda neat. They say it's "moisture and mildew repellent," but I'm not sure if it would be suitable for marine use.  http://www.silverstatefabrics.com/index.php?p_matter=items&p_item_collection=Celebrity%20-%20Faux%20Leather
Maybe that helps...
Kelly Frush
stitcher
I use the V and X pound densities
Cool Thanks Kelly I will have to check them out
Stitcher
Miami Mike
Nuvtex vinyl's. They get the job done. Nice working vinyl too.  Stitcher that seat turned out great. We offer several Nuvtex vinyl's.
  Specialty & Prints
http://www.miamicorp.com/default.aspx?page=customer&file=customer/micorp/customerpages/samples.htm
Foams for bike seats. Ask for a sample of the V400 or V625. Great base foams.
V400>FOAM, AQUA CELL V400 1" X 48" X 64"
V40034>FOAM, AQUA CELL V400 3/4" X 48" X 64"
V625>FOAM, AQUA CELL V625 1" X 42" X 56"
Exotic Leather
Quote from: Miami Mike on September 28, 2009, 03:52:18 pm
We have that Nuvtex as well, www.nuvtex.com.  It will perform at marine grade applications nicely.
