January 29, 2026, 09:31:01 pm
Cushion crown
Started by 65Buick, February 22, 2019, 04:59:12 pm
Got a T cushion, originally flat and no batting. Customer requests a crown.
I have a good piece of 4" i was hoping to use.
At that height though, would you sandwich a piece of 1/2" between two 2" for a really nice crown?
I was hoping to just use batting, but in this case I think it demands more.
You can get away with two payers of Dacron. One cut about 1.5" away from the edge of the foam and the other wrapped as normal. This give a decent crown but Dacron will flatten out with age. making a sandwich is a good way just make it larger than the finish size by about a inch all around and then cut the final size when its all glued up. If you want to finish at 4" foam at the boxing use 2-2" pieces with an 1" inside. You will probably want to shave the edges off the one in piece so it doesn't show a ridge after awhile.
  You can also grind off the edges of foam but it is messy and time consuming. But it gives the best cushion in my opinion.
Cool. So if I go the sandwich route would I cut but boxing a hair larger, like 4.5"?
I generally cut 4 1/4 for 4" foam but yes a bit larger for a seam allowance. Crowned cushions usually have a slightly smaller boxing than a non crowned cushion.
Analytically, a lot of patterning and effects can be realized in doing knife edge decorator pillows (no box).
So crown is controlled by the face(2) size/pattern of the pillow.  That is crown is controlled by the side
arcs cut in making the two sides.
This allows one to control the arc related to the pillow.
Carrying this forward in making box cushions with arc works very well.  It can done effectively several ways?  Arcing the face panels is another way.  The arc is engineered by the size of those.
Much of cushioning in older (?) days, the technique was along these reasoning.
Crown cushions can come out nice and fit the space in the furniture.
Crowning can be done with foam, marshal spring units , quite effectively.
Is the cushion made to be reversible? Is there a crown on both sides? If yes, make sure the crown is not too high so the cushion will sit on the deck fairly flat without gaps under the sides of the cushion.
This can be a problem on flat decks without a front edge.
Actually Gene, it wasn't specified. I was at the designer's house a she said to make it like her sofa which I believe was down.
The other thing is that the owner has 3 dogs, one of which jumped up on the chair while I was there.
Fortunately this will be the last thing I do so there is a bit of time to ponder.
Just on another note, the chair was stuffed using 100% synthetic cottonmI don't know of anyone who carries this stuff but it's a nice fill, doesn't compress. In my case I will use cotton.
What is the padding (cushion) fill "100 % synthetic cottonmI? Just another term for synthetic?
Or is it a combination?
Never heard this term used - don't think?
Doyle,
I've just seen this fiber referred to as synthetic cotton because it looks and acts like cotton felt... It is not dacron, it is a much smaller fiber.
For this cushion, I realize it would not be flipped. That's because it's floral and the boxing would be upside-down. So, if I take 4" foam, add a layer of pink 1/2 inch slightly smaller, then some cotton, and finally wrap top, bottom, front with dacron, will that give me a nice crown just on the top?
Building crown cannot ignore the geometry requirement in both the filler and cushion patterning.
Actually the crown is driven mainly in the face plates (top/bottom) of the cushion.  The overall thickness
of the crowned cushion is driven by the boxing.
Long ago, crown cushions were more in vogue than today.  Fillers were accomplished more differently,
before the flat foam wave, often it was coils and loose fillers of that period (cotton, down, etc.) - to name
some important type.
Thanks for the clarification on your material.
