May 21, 2026, 03:49:55 am
Serger
Started by SteveA, April 22, 2018, 03:56:18 pm
Paul if you want this Toyota I'll send it to you.  I will never use it enough to be worth keeping.  It's the model SL-1T look on line if you think it will work in your shop.  It needs a plastic platform thread stand (cracked)  - parts are available from Seiki Co. including cutters etc.  I have another light duty Singer that has a setting to stitch an edge in a pinch.
May 01, 2018, 06:09:58 am #16 Last Edit: May 01, 2018, 07:28:58 am by MinUph
That would be great Steve, Something to play with to see how it will work for us. Let me know costs and I'll send you a check.
  Thank you very much.
  Been reading up on this and it seems like it should do what I think it will do. This is great. I'll send my address in a private message Steve.
Nice little machine there. I wonder what is the difference with commercial vs home-type? My little brother is solid metal. I don't think a serger will work with the nylon type of parts found in home sewing machines.
Quote from: 65Buick on May 01, 2018, 08:13:57 am
Some of the little home sergers will struggle with upholstery weight fabrics. My industrial Juki serger will handle any weight fabric. But it will only accept lightweight serger thread. I believe Mojo said that his will sew 92 thread. For my needs, I only need to secure raw edges, so lightweight serger thread is fine.
The great thing about serger thread, it's insanely cheap compared to upholstery thread. About $3 for a 3000 yd cone.
Paul can I use the email address on your web site.... is that your best contact so I can make arrangements to ship it to you ?
Sure Steve. I did leave you a PM also. But the website email is good. Thanks
I have an 4 thread Elna. I was told it is a heavy domestic 😂 whatever that is. I use it on sunbrella cushion fabric & when I make up custom bedding.
This machine can do overlock & coverlock but I can't be arsed to change it over. So waste of money there..lol..
I did trial an industrial version once but found it to temperamental ( threads & needles breaking) and limited to one stitch style. The domestic is far more useful for what I do.
I also have domestic embroidery machine, just in case 😉
Hey Steve,
  I finally found some time at the shop to play around with the serger. Figured out how ti thread the thing for two threads. I pulled out the threads you had left in the thinking I want to figure out how to so I'll know. Won't do that again LOL. Anyway the third thread gave me issues I haven't figured out yet but I think two will suffice anyway. It worked great. It will be used for arm caps and head throws.
  I did try the rolled enge with only two threads and it worked fine. Just had to move the trimmer out of the way but I don't know how to keep the seam allowance even doing that. I doubt I will have a use for the rolled edge thing anyway. I'm happy with the edge serging.
  Thanks again. I owe you one.
All the best to you Paul - enjoy using it -
Steve
I saw on IG a very respectable designer/furniture maker in LA serges her edges before upholstering. I've thought of that before but I can't see why it's worth the time. Even for cushions.
Some fabrics just fray enough to test your patience -
I have a pinking shears that's good and sharp and does the job
