February 04, 2026, 01:34:05 am
Welt foot sizing
Started by MinUph, March 23, 2018, 12:17:35 pm
Does anyone have a chart with welt cord sizing and foot size to go with it. Like 5/32 cord takes 1/4" foot.
Here is a link Paul and rather than cut n paste their chart. I thought it probably has some benefit in the whole article. I know you have seen plenty in this regard so this in short order. If I run onto something real extensive this weekend it will be posted.
https://www.sailrite.com/Selecting-the-Right-Cording-Foot
Good day
Floyd
I can agree this chart Dennis recomended does have more or bigger cording selections. They also mention their material or fabric application. That application or how its put together is brought up here a bit or use to be.
Enjoy😎
USE:
This Welt Foot Set is commonly used to first make the welting by wrapping a 3/4" to 1" wide strip of fabric or vinyl or leather around 7/32" Diameter WELT.
Then this welting is inserted between two pieces of furniture or auto upholstery fabric to make the actual welted seam.
This is the most common method of sewing welted seams in furniture or auto upholstery.
This welt foot set will also sew regular seaming operations so you do not have to put your regular feet back onto the machine.
Many upholstery shops just leave this set on their machines all the time!
The most common sizes of welting foot sets for auto upholstery & furniture welting are  3/16"  1/4"  and  5/16".
To determine your correct LISTED SIZE, add 3/32" for your four plies of fabric to the WELT SIZE. So if you are using 5/32" welting add 3/32" for a total of 8/32" or 1/4".
LISTED (GROOVE) SIZE         USES WELTING SIZE
1/8"                                                    1/32"
3/16"                                                  3/32"
1/4"                                                    5/32"
5/16"                                                  7/32"
3/8"                                                    9/32"
1/2"                                                    13/32"
Thanks everyone. That works.
Don't forget the thickness of the fabric can affect the size of the foot that you would want to use also. So I don't see a chart being the end of the discussion.
Not the end Gene but a good starting point.
When the foot question arises, if my recent experience with the parameters of that job, I run a small
test to verify the welt foot size.
I don't do it but my Buddy uses 2 sizes of welting when he does double welt
Quote from: SteveA on March 25, 2018, 07:24:44 am
I've known some that do that. Because they use a method where the first row will have an extra layer of fabric wrapped around it, so they go up a size on the second cord.
Yes I am one that does this. 4/32 and 5/32
What I have to work with is three sizes of double cord welt feet.  Another parameter that I usually test
is how will it be attached:  (a)  stapled  or (b) glued?
That is part of my checking because the requirement may be important.
