January 28, 2026, 01:15:45 am
Headlining
Started by Grebo, September 22, 2017, 12:46:54 pm
I  have this customer, his boat is 10 years old & has alcantara covered headlining mostly on boards. This year the material went like bubbly in the heat of the summer ( most likely with the Aircon on as well) Now the weather has started to cool down they have all go flat & tight again !
Is there a cure for this ? Or is it just age of the glue/ break down of foam backing or something. ?
I am not familur with this fabric but it sounds like the glue has failed and the heat allowed the fabric to sag.
Hmm, makes sense, strip down job them. Ta
I would be curious if the boarding the fabric is glued to was easily removeable. My mind can see a few options here on the boat ceiling, like accessible control or piping equipment in the area. The removal of the old stuck foam could be a real pain in any situation.
Good day there
Floyd
if Alcantara is the stuff I'm thinking of * I've seen it fail as auto headling in that ten year time. The dense foam backing just turned to dust.
* The stuff I'm thinking of is sold here for auto headliners. It's about 3-4 mm (3/16") thick with a velour type fabric and dense foam  rubber backing.
September 25, 2017, 02:42:22 am #5 Last Edit: September 25, 2017, 02:44:11 am by Grebo
Quote from: Darren Henry on September 23, 2017, 08:39:22 am
Similar, more like a suede finish & foam backed I believe, boat is in France not local to me.
Foam backings often turn to dust here, I guess heat & age.
