February 12, 2026, 07:52:36 am
Newly Acquired: Pfaff 545 H4
Started by lilsuz, October 13, 2013, 10:24:18 am
lilsuz
Hello Everyone!--
Well, I've got a new machine and it is a Pfaff 545 H4. I see that there are quite a few of you here who have this machine, so perhaps you can help me out. I'm working on the machine myself, as it has not been run for a few years and needs lots of little adjustments.
There are a couple screws that I need to get for it, I think that I need just one more part number though before I order.
Needed parts:
(Stripped) Screw #91-000-699-15   (goes below the bobbin area)
(Stripped) Screw #11-174-086-15   (at end of needle bar - holds the needle in)
(Stripped) Screw # (?)  Need part #, This is the Screw that holds the needle bar in position
About the last screw on my list, I think it is also referred to as "screw 2" from the directions I am using on Page (9) of the "Pfaff 1245 1246 Adjustment Manual"
Wish I had a part number for the screw. Anybody?
Also, if anybody knows what these parts cost, that would be great too.
Thanks in advance!
Is it the heads of the screws that are stripped? Or the threads?
If it's the threads, you may have to replace the parts that those screws go into.
But if you just need the screws, I can't imagine them costing more than a few dollars each.
Call the place that Paul linked. They should have them.
