January 19, 2026, 10:14:32 pm
What Glue would you use to glue vinyl into plastic bases
Started by JDUpholstery, January 16, 2013, 04:23:19 pm
HH-66 is wonderful stuff.  Don't know if it will work for your application, but it's an amazing adhesive.  I'd certainly give it a try.
JDUpholstery
Heres some pics, I ended up just doing a wrap-around of the plastic base instead of trying to glue it into the "socket" like it was from the factory
This is the plastic base, where the cushion and vinyl were glued into it, leaving the plastic showing all the way around the cushion
and this is how I ended up doing it, just wrapping the plastic and cushion both
Nice job JD. What kind of vinyl did you use and how did you get it to stretch that tightly around those curves? You must have one heck of a heat gun. It looks like you painted it on LOL.
QuoteHH-66 is wonderful stuff
In my former life as a shoe maker we tried every vinyl cement we could find and HH-66 was the only one that would actually work for one style of Redwing boot soles (We were their warranty depot in Winnipeg) and by far the best on the other applications.
If you REALLY want it to stick -- disregard the label instructions. Apply one coat to both surfaces/let dry one hour.Repeat. Re-activate the glue with a heat gun and press your two surfaces together. A wallpaper roller works great for this or you can use the face of a hammer as an iron.
I once made a 5000 lb lift bag out of Vintex (Herculite etc...). Picture a 13 foot sausage as wide as the roll would allow.All seams were 1 1/2" overlap and all sewing was "sealed" with HH. At 90 feet (three atmosphere's of pressure plus enough to keep it inflated) there were no air bubbles even under load.
JDUpholstery
I used a standard 32oz marine vinyl, and a lot of heating in the right spots....I basically did this job twice since the gluing into the "socket" factory method was not working for me....It did come out pretty tight, was pleased with myself actually lol
