February 12, 2026, 01:21:46 pm
Leaky air fittings
Started by sofadoc, December 08, 2012, 07:59:09 pm
Id think the preasure Gene would help you fart swuueze it right out
Maybe a. It more then a fart a "shart"
I hereby nominate Gene as the "King of Useless Information"!  Not many furniture upholsters at 33' below.  But fun info anyway  :P
My couplings all hiss as well whenever you move the hose. I just bought a 3 way coupling so I can connect 3 different hoses to it and run 3 different pressures through small regulators. My coach tires require 120 PSI. Some of my big nail guns require 100. My staplers and brad nailers I run at 60 - 70 psi. I do believe June is correct and I will look into replacing the O rings. This sounds like the right way to go.
I nominate June as the Queen of knowledge.  8) 8)
This is the set that I'm talking about:
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-100045934/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=air+fittings&storeId=10051
What O-rings?
I can completely eliminate the hissing by replacing these 2 parts. Trouble is, I have to replace them monthly. I realize that it's only 6 bucks. But I used to go years without needing to replace them.
If there is a more expensive set that you guys recommend, lay it on me.
QuoteScuba divers cannot fart below a depth of 33 feet
Just as well. I wear a 10mm wet suit and only 16lbs of weight.If I've got my hood and gloves on I'd be headin' for the boat like a little cork.LOL.
Sofa D: I found that the zinc plated silver coupler lasts a lot longer than the brass colored one.
December 10, 2012, 06:24:01 pm #21 Last Edit: December 10, 2012, 06:44:41 pm by JuneC
Quote from: sofadoc on December 10, 2012, 03:24:26 pm
What O-rings?
The female fitting has an o-ring in the bottom of it.  You can kinda see one in this pic, though this isn't the exact one I have.
  http://www.farmerboyag.com/supplies/female-quick-connects.asp
I've never changed mine, but there is a tool that makes it easier.  See the very bottom of this page where they show o-rings.  You can use a dentist's pick to pull out the old one, but that would probably be more expensive than this tool.
   http://www.ultimatewasher.com/fittings-connectors.htm
Hansen is supposed to be a good brand of high pressure fittings.  Maybe these guys could help.
 http://www.pressuretek.com/couplers.html
Actually, this company appears to carry a broader range of products.
   http://www.nycoil.com/couplers/couplers.html
I just bought twp sets of dental picks ( 5 per set - different angled tips ) for $ 1.98 at harbor freight.
If you hold the female coupling and look into it you will see the black rubber O-Ring.
BTW, harbor freight sells O-Ring kits for $ 5.00. It is a plastic storage container that is filled with different sized o-rings. I believe they also have nitrile o-rings.
June:
The Farmerboy link reminded me that I haven't tried my local farm supply store. If I don't see anything there, then I'll order from one of those websites. Thanks.
Once I get some quality couplers and plugs, then I'll look into O-rings if it should become necessary.
Some people are seemingly unperturbed by a hissing air connection. Yet if they had a leaky water fawcett, or a toilet that won't stop running, they would fix it.
