February 02, 2026, 11:53:10 am
Pontoon Corner cushion
Started by JDUpholstery, November 16, 2012, 03:03:40 pm
If im making a cushion i will pattern the foam but 99% of the time like the pontoon in my previous post i use the old skin for a pattern like the article. Saves alot of time.
I almost always pattern off the foam.  The only time I pattern off the old vinyl is if it really isn't old (and misshapen) at all - like if it got damaged and has to be replaced but is still basically new.  I find that it can't really be laid flat enough to get a good image and even those pieces that can be will mess up the fit.
Darren that's almost exactly how I do it. But I pattern all the pieces at the same time, I don't draw lines on the foam. I make all my patterns finished size and the seam allowance gets added at the table. I use 1/2" staples to staple the pattern to the foam, like rapid fire pins.
Trying it on before top stitching is a good tip.
JDUpholstery
So customer came today and took the boat, I still need to recover console, and am working on the Bimini in shop now, but he was pretty durn happy...I just could not get rid of that one wrinkle in the corner cushion but he said it did not bother him...
Thanks for all the tips and tricks, I just know my next one is going to be that much better and easier....not to shabby considering my first sewing attempt in my life was only a year ago!
QuoteI use 1/2" staples to staple the pattern to the foam, like rapid fire pins.
I'll have to try that sometime. I usually only need to use 4-6 skewers doing it one panel at a time,but if you're going to "mummify" the hole piece, I can see where that would really save time.
November 23, 2012, 03:18:13 pm #20 Last Edit: November 23, 2012, 03:20:47 pm by MikeM8560
not nad at all jd
Darren what do you kek on the foam with ?  ive had sharlie burn though the vinyl doin gthis and learned my lesson
ometimes I take that heat gun and hit the old hard crusty skins with it . It softend them up and takes out the memory of being that curve for the last 10 years. It helps if you're gonna use them for a pattern.  :o
QuoteI take that heat gun and hit the old hard crusty skins with it
I use a steam iron ,set on max steam/lowest temp. that will give me that .
Mike; I just use a sharpie. Our weather is more like you had in N.H, not that insane humidity/heat in Fl. I've never had a problem (yet , cross fingers).
