February 07, 2026, 12:04:37 am
Clamp on jawslids 2"
Started by Mike, April 04, 2012, 01:21:15 pm
I priced s little sailboat job yesterday but it is all depends t on finding a pair of 2" stainless clsmp on jaw slide just like the 7/8" - 1 1/4" we all know  the boat had some mounti g a top foward off a pipe arch the owner waned to do somthin off the rear with spreader bars.  But i cant find any
U know me and Google  ;D  3rd one down....  Expensive! bits they are.  ::)
http://www.canvasuphcenter.net/Jaw%20Slides.html
Ahb your a jeWel  June !
We dhould have your post count changed from yabb god to
Google god ! Or goddess ;)
Oh hey.   Just found it on Trivantage website.  P/N 284261.  Comes in 1.5 and 2".  $31 for the 2"
Quote from: MikeM8560 on April 04, 2012, 04:26:36 pm
I vote for Goddess.  ;D
DBR1957
Mike - Are you attaching to SS tubing or aluminum pipe? I didn't see the part June
pointed out but if it's from Trivantage I'm sure it's SS for tubing. In your original
post you said pipe. SS hardware dimensions won't work on pipe. If you actually
need a split clamp for pipe check Taco, E-Tec or Eatern Metal Supply
April 08, 2012, 10:55:44 am #6 Last Edit: April 08, 2012, 11:58:39 am by MikeM8560
This boat  had stainless   Clamp
On jaws just like the normal 1" seen   Snd it was an aluminum arch.
I looked real quick on my phone but didnt see them.  Do they easter have. Imini frame fittings?
Thanks dbr
Ive used 7/8" and 1" hindved jaws but only on stsinless rails seems like 1" on my tape are you saying the aluminum pipe is off  different then stainless pipe?
DBR1957
Tubing is defined by outside diameter while pipe is defined by inside diameter.
I.E., 2" tubing is 2" outside. 2" schedule 40 pipe is approximately 2.5" outside
diameter. Schedule 40 pipe is typically what is used for aluminum arches.
However, 1.5" pipe is close to 2" outside diameter so it might work. Don't be
be surprised if a stainless split jaw is a little loose or somewhat to tight.
I've had to mount to aluminum arches before but it was larger pipe. I had to get
split collars and weld tabs to them. If you're working with smaller pipe the
stainless split may work fine.
Got a pic?
