January 30, 2026, 02:57:06 pm
Hot Knife for foam cutting?
Started by Ageorge, December 14, 2011, 01:09:46 pm
Ageorge
I'm researching some alternatives to my electric knife for cutting foam, and ran across this hot knife on amazon.
http://www.amazon.com/Hot-Knife-Straight-Blades-Case/dp/B0045ZS0XK/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I2SRNQK144S4KO&colid=2N7DA2RMOUO76
Has anyone used anything like this?
I can't imagine it being as good as a foam saw.
Saddleman
Those are for cutting expanded or extruded polystyrene foams not flexible urethane based foams used in upholstery.
CreativeCanvas
Keep your eye on eBay.  Sometimes a good deal can be had there...  Or Craigslist.
Triple ditto.
I couldn't figure out how that would cut furniture foam (polyurethane). It doesn't. This same guy, or company, lists this item elsewhere as a "packaging foam" cutter. Able to sculpt the foam. Yes, it's for polystyrene foam.
December 15, 2011, 02:53:52 pm #6 Last Edit: December 15, 2011, 02:55:31 pm by fragged8
hot wire on upholstery foam isn't a good idea
the fumes will be poisonous
scroll up to the top of the page and click on the text link
that says ' foam cutters $149'
I have  the 8" one about half way down the page
looks like an angle grinder or disk cutter  and its not bad at all
and a bargain if you look at the price of a Bosch cutter.
rich
I have the 8" Acu Cutter where both blades move.  I love it.  Worth every penny!
CreativeCanvas
Beth has an ancient "Foam Queen". Single blade. Believe it's 8" but might even be a lil more? I'll try'n remember to measure it tomorrow.
She was using it awhile back when it started shooting sparks. Heh heh. Took it apart & determined the motor brushes were shot. Found some that were close & filed them down to size. Seems to be fine now.
Ya 'styrene' & 'polyurethane' require different cutters?
Quote from: bobbin on December 15, 2011, 03:11:20 pm
And we are helping support Ken  ;D which cant be bad
R.A.F. CaNvAs
  Didn't notice the the breathing apparatus in the box with the hot knife.
   What's wrong with a panel saw and some elbow grease anyhow,
