January 30, 2026, 09:22:22 am
CHAFE POINTS ON A DODGER
Started by Lmc530, December 13, 2011, 07:46:39 am
Lmc530
Looking for suggestions.. What is the best material to use on chafe points on a dodger..?
I use either hurculite or tuff stuff in  a matching color
Lmc530
So many different fabrics from Herculite.. which do you use?  Riviera, Regatta, Regatta II, Aqua-tex II..?
RandyOnR3
  Depending on where the point is.....
If its where the lines run from the mast to the cockpit, I bind it with leather as well as the lower outer edge of the dodger where a sheet might pass by..
If its inside where a joint might be wearing against the fabric.. I use scrap stradaglass neetly sewn in place..
Over the forward and rear top of the dodger, where hand holds might be, I use a heavy vinyl....
